Main relay to fuel,ign,inj relays correct wiring?
How to Degree a Cam
Hi,
I've got a eaton bussmann fuse/relay box.
I’m wiring it up so when the main relay is switched on it will then switch on 3 relays. Fuel, ign and inj’s though pin 87.
The question I have is what’s the best way to connect the 3 switched on relays through the main relay 87 pin?
Do I cram all 3 relay wires into the 87 pin or splice in between the main relay and the 3 others.
I’ve attached a photo of the eaton bussmann I’ve got with the wire routing shown.
The main relay 87 pin is red and the yellow pins are the other relays.
Thanks in advance.
