bosch 1000cc high impedence injectors
Introduction to Engine Tuning
hi, I'm trying to calibrate these injectors to my ecu but I don't have the relevant specs for these injectors
I tried the company I bought them from who told me to look on bosch website but I cant find anywhere
any help?
There's a lot variance between 1000cc injectors but this is what I'm using for my Bosch 1000s. Probably not exactly what yours are but will probably get you in the ballpark.
First set of numbers is battery voltage. Second set is injector dead time.
6.00
7.00
8.00
9.00
10.00
11.00
12.00
13.00
14.00
15.00
16.00
17.00
18.00
2.95
2.835
2.72
2.18
1.705
1.5
1.295
1.148
1
0.905
0.81
0.71
0.71
thank you very much
Please be aware that the dead time values will also depend on the differential fuel pressure so a single set of dead time values alone won't tell you the full story.
Please then assist Andre, I'm not asking for the exact specs for my injectors however there is so much info out there and it makes it mind blowing to try to find correct or at least subpar info for any injectors nowadays , even if one was to purchase from a well known company DW 1000cc they'll give you some irrelevant information and on top of that ask them for a 3d table such as for a link engine management and you get something as good as nothing ? I have found injector data that is very subpar however uses fuel pressure rather than differential and everywhere teaching to tune shows you should be using fuel pressure differential x voltage again using a dw set of Bosch 1000cc injectors ! 1 more thing to touch on injector short pulse width adder? How important is this information with a set of 1000cc injectors rather should it just be left to all 0?
