CSV logs analysing software
Introduction to Engine Tuning
Hi guys,
I use VehiCAL logger (https://www.vehical.net/products/logger/) for logging my 718 cayman, and I get them in CSV format.
I usually view them on datazap, its convenient and works fine: https://datazap.me/u/mladjan/new-ch-10c?log=0&data=100
But, when I want to open two logs and overlay IAT graph from one to another file, there is a limitation.
I have used SView for that, but the import procedure is painful, and last time I was able to modify CSV to work, but now my CSV doesn't work properly and crashes SView.
Is there any good software for generic CSV logs with features for multiple file comparison?
I prefer web versions (I use MacOS as my main machine), but windows is also OK.
You will probably like MegaLog Viewer HD. Works with Macs and Windows. https://www.efianalytics.com/MegaLogViewerHD/
I have downloaded it, and tried, but how to use two logs at the same time and overlay data? :)
Try using File->Compare To... I believe this will open another log file.
I don't see that option in the menu. Have tested MacOS and Win version.
That feature is only available with the HD version. I think it's worth the cost.
Purchased, and now it works!
its not best looking software, its all slow and blurry on MacOS, but I hope it does the job :)
Plex Tuning analysis software is really strong and of course MoTeC i2pro with .CSV import option.
Not cheap but one of the best arround.
