Ecumaster for Lotus Elise
Introduction to Engine Tuning
Hi, recently i buy a Ecumaster EMU Black Plug and Play for my 2021 Lotus Elise 250 CUP with 2ZR-FE engine super charged, the problem is that i connect de ECU y the car doesn't cranking, this car has button push for turn on the engine. already have setup the trigger, AIN, Output, VE Table ang ignition table but doesn´t turn on.Is first time that i use Ecumaster.
The car has DBW throttle, OEM coils, Injector and supercharger pulley for now....
I attach the map.
I hope that you can help me.
Do you have the factory wiring documentation as to how the push-button functions?
Does it go to some type of relay or power-control box, or did the factory ECU support that directly?
I could see how a PMU could support a push button switch to toggle the ignition, and allow starting with a long press or something. Not sure how a powered off ECU would be expected to deal with it.
Hi David, no, I don't have the factory pinout.
Factory ECU support directly.
I install the factory Ecu and the car starts!
The standalone ECU turn on, I can connect to it and see the connected inputs and outputs but the engine doesn't cranking with the factory star button
