No spark - Haltech E11V2 4age
Introduction to Engine Tuning
Hi guys, I am having issues getting spark trying to set base timing. Engine is a 4age with 1zz coil on plugs. Using the factory toyota 24-1 reluctor sensor. ECU is a Haltech E11V2
Seeing 180-230 rpm when cranking, 24 trigger count since last home.
Have manually excited the coils by providing 12v to IGT and all looks OK.
Will always spark once when I stop cranking.
ECU stays powered when cranking. No significant voltage drop when cranking either.
Double checked my wiring to the reluctor sensor and have confirmed polarity.
Settings as per attached pictures.
