black 3-5 conducter wire shielded temp stable
I'm looking for wires like the Spec 44 shielded ones but in black. With 3-5 conductors.
The usual DIY Auto-grade trigger cables are only temperature resistant up to 70-80°C
The cable must be temp stable at least to 120°C and should be not too expensive.
The reason I ask is, street car customers are often not willing to spend several hours to make a MIL-Spec harness. And to be honest a good, shielded cable which is temperature stable does the job abundantly.
Why don't you just put black DR-25 over your Spec 44 wire?
It's possible but end up a bit costly and needs additional time.
Think would be a bit over the top for usuall street cars.
