Emtron tmf tuning
Good morning guys does any one have a detailed guide on how to setup and use tmf to tune the fuel mapping ?
Luke,
Is there a particular part of Emtron's how to guide for TMF tuning which you're hoping for help with specifically?
Throttle Mass Flow Setup (emtronaustralia.com.au)
Please let me know and hopefully we can clarify things.
Yeah just want more in depth like do we need to change the axis on the ve table to anything?
And with method 3 to matching lambda so we tune Throttle Body Area Table to match lambda at the different areas.
before we start doing the ecu mapping? i am more of a visual learner to get my head around things.
Got it.
Mode 4 TMF + SD has been Emtron USA's suggestion to me, which does still involve a typical VE table and axes, but that is one of multiple possible approaches. Emtron gives you a lot of flexibility and what works best for you will be a combination of your preference and what you're tuning.
The Emtron worked example HPA offers combined with the run through in the video I've cued up below will give you a combo of the TMF info and SD tuning.
https://youtu.be/3I-69xixL9E?si=rpT0F_fpXrnyU4qW&t=390
