Knock sensor reading
Hi guys,
I have a build with a 1JZ running on ECU Master. I'm currently setting up the knock sensor (stock 1JZ one-wire sensor) but from the logs I see 4.92V when the car is off and then 0 volts as soon as the car starts.
I've set the knock parameters to (I've found this is what the 1JZ sensor should be set at):
- 6.94Khz frequency
- 0.182 Gain
- 200 uSec integrator
What exactly could I check to diagnose the reading issue? Are the params at least in the ballpark to get a decent reading?
https://www.dropbox.com/s/ejqkf94ameoi5ea/Screenshot%202021-04-28%2020.44.47.png?dl=0
check this drop dox for an approx setup but it sounds like you may have a wiring or sensor issue
Regards Ross
Hi Ross,
Thanks for your inpuy. I made some modifications based on it with no luck so I guess it's a sensor/wiring issue.
I will replace with a bosch knock sensor since the stock one is very prone to fail from what I've researched only.
