Setting up my haltech elite 2500
Need some help getting my haltech elite 2500 setup in my vs 355 manual ute
What exactly do you need help with?
Need help with everything. From setting up sequential injection and individual coils trigered from a vt 5l distributor. Knock sensor setup. Tables. Engine protection. I have a single o2 HALTECH controller but want to run 2 for bank control. Can i buy another single or do i need a dual controller.
My current setup is a haltech gm platinum sport ecu
So did you watch the courses and webinars first?
Yes i have watched and done lots of research. But just wanted more info on it so i didnt stuff it up
There are two way you could approach this depending on your experience. If you have setup stand alone engine management from scratch before or feel up to the task follow the 10-step process found here.
Or
If you are already running well with the platinum sport ECU, you could first move to the Elite 2500 using the same settings and tables and then add the new features you are looking to use one at a time and learn as you go.
