EVO 9 Motec m800 Tibuc als HELP
Member Introductions
Hello guys! currently helping a friend out with he's evo 9 with motec m800 PNP.
have anyone here wired a Tibuc ALS valve/controller into m800? the DIG4 is free so we planned to use that. the thing i wonder is how the rest i wired. have this only drawing for wireing the Tibuc controller. (see attached file) so here is where i have a few questions:
1 - ground
2 - 12v
3 - activation through switch (?) to ground
Then comes what I'm unsure about.. should pin 3 also go to the ecu?
And what should I do with pin 4-5?
And should pin 6-7 also go into the ecu together??
i find the drawing of how to wire a bit hard to understand.
Also swithed fron id850cc to bosch 1200cc so if anyone could recive the ecu file and change the injector scaling that would be sweet. never messed with motec so all is a bit new and old school compared to maxxecu that i like to play with!
-Amund
Can't help you with motec, sorry.
May I ask why the choice is standalone ecu and additional valve?
Stock ECU can do a lot of things these days...
https://m.youtube.com/@pisyakot
It's likely you will need to re-visit the fuel map with your new injectors. But you could start by updating the Injector Battery Comp table with the new dead times, and just multiplying the current IJPU (Injector Pulse Width Scaling) value by 850/1200 = 0.71
@georg1970 he did not want to go dbw and motec was already in car when i bought it. And got the Tibuc valve with controller for cheap
@david Ferguson thanks alot! car will be tuned on dyno by a tuner. just need it to be running
Please let us know how it's going, if you've got the engine started.
still no progress. trying to figure out the tibuc wiring. seems a bit hopless atm
Amund,
Sorry for the trouble. Is the manufacturer of the system able to send instructions completely in English?
That would help me better assist, but the drawing is also a bit confusing and doesn't include explanation of how the system works.
Is there other accompanying documentation?
