Connect PAL CAMERA to C127 dash with Display Creator.
Practical TIG Welding
Discussion and questions related to the course Practical TIG Welding.
Hi all, I would like to connect a Motec 12V PAL camera to a C127 dash which is currently using display creator.,
I need some advice on how to connect the reverse gear switch signal to activate the camera in the C127 Dash.
I can connect the reverse sensor signal to an AV input on the C127 but how do I activate the camera? Do I use C127 Dash manager to enable the video to show on the c127 dash? Or should the camera video setting be activated in Display creator?
Thanks in advance.
Hi Edmund,
Put the Camera into a switch group, and set the switch group with the condition to be based on the reverse switch
Hey Nathan, thanks for this!
