Lb7 efi live tuning turbo for desired boost
Practical TIG Welding
Discussion and questions related to the course Practical TIG Welding.
I am tuning an lb7 Duramax and wondering if there is a conversion you can use to calculate the boost you should make. I know on the vvt turbos you subtract 14 from the boost table, just wondering if there is a way to convert it on the lb7 because I'm seeing way higher numbers and the conversion for the vvt does not work.
Thank you
