Unable to Download ROM w/ECU Flash
Practical TIG Welding
Discussion and questions related to the course Practical TIG Welding.
First time attempting to connect using Tactricx Openport 2.0 and ECU Flash software. Vehicle is a JDM 2007 Impreza STI non-DBW. When attempting to connect I receive an "Error occurred see log file for details" message. Below is the log file data. Any advice will be greatly appreciated. Thank you.
[11:05:45.022] Logging to file C:/Users/jgper/AppData/Roaming/OpenECU/EcuFlash/logs/ecuflash_log_20220319t110545.txt
[11:05:45.022] 6 old log files deleted
[11:05:45.022] EcuFlash Version 1.44.4870
[11:05:45.022] OS Version Windows 10
[11:05:45.022] Kernel Type winnt
[11:05:45.022] Kernel Version 10.0.19042
[11:05:45.022] CPU x86_64
[11:05:45.022] Product Name Windows 10
[11:05:45.022] Product Type windows
[11:05:45.022] Product Version 10
[11:05:45.022] Qt Version 5.6.0
[11:05:45.022] Qwt Version 6.1.2
[11:05:45.022] QwtPlot3D Version 0.2.6
[11:05:45.022] Boost Version 1.60
[11:05:45.022] FTDI Library Version 3.02.11
[11:05:45.022] Openport J2534 Library Version 1.02.4870
[11:05:45.030] 67 memory models read.
[11:05:45.030] scanning for metadata models in C:/Program Files (x86)/OpenECU/EcuFlash/rommetadata
[11:05:45.375] 745 ROM metadata models scanned.
[11:05:45.375] checksum module "subarudbw" loaded.
[11:05:45.376] checksum module "subarudiesel" loaded.
[11:05:45.376] checksum module "subaruhitachi" loaded.
[11:05:45.376] checksum module "mitsucan" loaded.
[11:05:45.376] checksum module "mitsuh8" loaded.
[11:05:45.376] patch module "Subaru CAN Enhanced RAM Parameter Logging" loaded.
[11:05:45.376] patch module "Mitsu CAN RAM Parameter Logging" loaded.
[11:05:45.378] using metadata XML ID read_sti05 from file C:/Program Files (x86)/OpenECU/EcuFlash/rommetadata/read templates/read_sti05.xml
[11:05:45.382] flashing tool "wrx02" loaded.
[11:05:45.384] flashing tool "wrx04" loaded.
[11:05:45.385] flashing tool "sti04" loaded.
[11:05:45.386] flashing tool "sti05" loaded.
[11:05:45.388] flashing tool "mitsucan" loaded.
[11:05:45.388] flashing tool "mitsukernel" loaded.
[11:05:45.388] flashing tool "mitsukernelocp" loaded.
[11:05:45.388] flashing tool "mitsubootloader" loaded.
[11:05:45.388] flashing tool "shbootmode" loaded.
[11:05:45.388] flashing tool "shaudmode" loaded.
[11:05:45.390] flashing tool "subarucan" loaded.
[11:05:45.391] flashing tool "subarucand" loaded.
[11:05:45.392] flashing tool "subarubrz" loaded.
[11:05:45.394] flashing tool "subaruhitachi" loaded.
[11:05:45.447] J2534 API Version: 04.04
[11:05:45.447] J2534 DLL Version: 1.02.4870 Feb 3 2017 23:36:31
[11:05:45.447] Device Firmware Version: 1.17.4877
[11:05:45.447] Device Serial Number: TA41g3Qb
[11:05:45.447] interface close
[11:05:45.479] J2534 API Version: 04.04
[11:05:45.479] J2534 DLL Version: 1.02.4870 Feb 3 2017 23:36:31
[11:05:45.479] Device Firmware Version: 1.17.4877
[11:05:45.479] Device Serial Number: TA41g3Qb
[11:05:45.480] interface close
[11:05:45.510] J2534 API Version: 04.04
[11:05:45.510] J2534 DLL Version: 1.02.4870 Feb 3 2017 23:36:31
[11:05:45.510] Device Firmware Version: 1.17.4877
[11:05:45.510] Device Serial Number: TA41g3Qb
[11:05:45.511] interface close
[11:05:45.541] J2534 API Version: 04.04
[11:05:45.541] J2534 DLL Version: 1.02.4870 Feb 3 2017 23:36:31
[11:05:45.541] Device Firmware Version: 1.17.4877
[11:05:45.541] Device Serial Number: TA41g3Qb
[11:05:45.542] interface close
[11:05:45.571] J2534 API Version: 04.04
[11:05:45.571] J2534 DLL Version: 1.02.4870 Feb 3 2017 23:36:31
[11:05:45.571] Device Firmware Version: 1.17.4877
[11:05:45.571] Device Serial Number: TA41g3Qb
[11:05:45.572] interface close
[11:05:45.601] J2534 API Version: 04.04
[11:05:45.601] J2534 DLL Version: 1.02.4870 Feb 3 2017 23:36:31
[11:05:45.601] Device Firmware Version: 1.17.4877
[11:05:45.601] Device Serial Number: TA41g3Qb
[11:05:45.602] interface close
[11:08:56.569] using metadata XML ID read_sti05 from file C:/Program Files (x86)/OpenECU/EcuFlash/rommetadata/read templates/read_sti05.xml
[11:09:02.297] using metadata XML ID read_sti05 from file C:/Program Files (x86)/OpenECU/EcuFlash/rommetadata/read templates/read_sti05.xml
[11:09:02.314] J2534 API Version: 04.04
[11:09:02.314] J2534 DLL Version: 1.02.4870 Feb 3 2017 23:36:31
[11:09:02.314] Device Firmware Version: 1.17.4877
[11:09:02.314] Device Serial Number: TA41g3Qb
[11:09:09.741] kernel get version
[11:09:09.944] interface close
[11:09:09.975] J2534 API Version: 04.04
[11:09:09.975] J2534 DLL Version: 1.02.4870 Feb 3 2017 23:36:31
[11:09:09.975] Device Firmware Version: 1.17.4877
[11:09:09.975] Device Serial Number: TA41g3Qb
[11:09:10.167] interface close
[11:09:10.206] J2534 API Version: 04.04
[11:09:10.206] J2534 DLL Version: 1.02.4870 Feb 3 2017 23:36:31
[11:09:10.206] Device Firmware Version: 1.17.4877
[11:09:10.206] Device Serial Number: TA41g3Qb
[11:09:10.390] SSM2 init
[11:09:10.550] SSM2 ECU ID is 4304594005
[11:09:12.577] interface close
[11:09:12.592] interface close
[11:09:28.162] using metadata XML ID read_sti05 from file C:/Program Files (x86)/OpenECU/EcuFlash/rommetadata/read templates/read_sti05.xml
[11:09:28.189] J2534 API Version: 04.04
[11:09:28.189] J2534 DLL Version: 1.02.4870 Feb 3 2017 23:36:31
[11:09:28.189] Device Firmware Version: 1.17.4877
[11:09:28.189] Device Serial Number: TA41g3Qb
[11:09:32.794] kernel get version
[11:09:32.997] interface close
[11:09:33.014] J2534 API Version: 04.04
[11:09:33.014] J2534 DLL Version: 1.02.4870 Feb 3 2017 23:36:31
[11:09:33.014] Device Firmware Version: 1.17.4877
[11:09:33.014] Device Serial Number: TA41g3Qb
[11:09:33.220] interface close
[11:09:33.250] J2534 API Version: 04.04
[11:09:33.250] J2534 DLL Version: 1.02.4870 Feb 3 2017 23:36:31
[11:09:33.250] Device Firmware Version: 1.17.4877
[11:09:33.250] Device Serial Number: TA41g3Qb
[11:09:33.423] SSM2 init
[11:09:33.583] SSM2 ECU ID is 4304594005
[11:09:35.598] interface close
[11:09:35.614] interface close
[11:09:39.991] using metadata XML ID read_sti05 from file C:/Program Files (x86)/OpenECU/EcuFlash/rommetadata/read templates/read_sti05.xml
[11:09:40.017] J2534 API Version: 04.04
[11:09:40.017] J2534 DLL Version: 1.02.4870 Feb 3 2017 23:36:31
[11:09:40.017] Device Firmware Version: 1.17.4877
[11:09:40.017] Device Serial Number: TA41g3Qb
[11:09:48.231] kernel get version
[11:09:48.435] interface close
[11:09:48.467] J2534 API Version: 04.04
[11:09:48.467] J2534 DLL Version: 1.02.4870 Feb 3 2017 23:36:31
[11:09:48.467] Device Firmware Version: 1.17.4877
[11:09:48.467] Device Serial Number: TA41g3Qb
[11:09:48.659] interface close
[11:09:48.684] J2534 API Version: 04.04
[11:09:48.684] J2534 DLL Version: 1.02.4870 Feb 3 2017 23:36:31
[11:09:48.684] Device Firmware Version: 1.17.4877
[11:09:48.684] Device Serial Number: TA41g3Qb
[11:09:48.868] SSM2 init
[11:09:49.029] SSM2 ECU ID is 4304594005
[11:09:51.048] interface close
[11:09:51.064] interface close
[11:10:57.659] using metadata XML ID read_sti05 from file C:/Program Files (x86)/OpenECU/EcuFlash/rommetadata/read templates/read_sti05.xml
[11:10:57.672] J2534 API Version: 04.04
[11:10:57.672] J2534 DLL Version: 1.02.4870 Feb 3 2017 23:36:31
[11:10:57.672] Device Firmware Version: 1.17.4877
[11:10:57.672] Device Serial Number: TA41g3Qb
[11:10:59.785] kernel get version
[11:10:59.988] interface close
[11:11:00.019] J2534 API Version: 04.04
[11:11:00.019] J2534 DLL Version: 1.02.4870 Feb 3 2017 23:36:31
[11:11:00.019] Device Firmware Version: 1.17.4877
[11:11:00.019] Device Serial Number: TA41g3Qb
[11:11:00.211] interface close
[11:11:00.240] J2534 API Version: 04.04
[11:11:00.240] J2534 DLL Version: 1.02.4870 Feb 3 2017 23:36:31
[11:11:00.240] Device Firmware Version: 1.17.4877
[11:11:00.240] Device Serial Number: TA41g3Qb
[11:11:00.425] SSM2 init
[11:11:00.586] SSM2 ECU ID is 4304594005
[11:11:02.605] interface close
[11:11:02.606] interface close
[11:11:19.508] using metadata XML ID read_sti05 from file C:/Program Files (x86)/OpenECU/EcuFlash/rommetadata/read templates/read_sti05.xml
[11:11:19.536] J2534 API Version: 04.04
[11:11:19.536] J2534 DLL Version: 1.02.4870 Feb 3 2017 23:36:31
[11:11:19.536] Device Firmware Version: 1.17.4877
[11:11:19.536] Device Serial Number: TA41g3Qb
[11:11:25.633] kernel get version
[11:11:25.849] interface close
[11:11:25.881] J2534 API Version: 04.04
[11:11:25.881] J2534 DLL Version: 1.02.4870 Feb 3 2017 23:36:31
[11:11:25.881] Device Firmware Version: 1.17.4877
[11:11:25.881] Device Serial Number: TA41g3Qb
[11:11:26.061] interface close
[11:11:26.096] J2534 API Version: 04.04
[11:11:26.096] J2534 DLL Version: 1.02.4870 Feb 3 2017 23:36:31
[11:11:26.096] Device Firmware Version: 1.17.4877
[11:11:26.096] Device Serial Number: TA41g3Qb
[11:11:26.282] SSM2 init
[11:11:26.442] SSM2 ECU ID is 4304594005
[11:11:28.461] interface close
[11:11:28.477] interface close
[11:11:35.932] using metadata XML ID read_sti05 from file C:/Program Files (x86)/OpenECU/EcuFlash/rommetadata/read templates/read_sti05.xml
[11:11:35.956] J2534 API Version: 04.04
[11:11:35.956] J2534 DLL Version: 1.02.4870 Feb 3 2017 23:36:31
[11:11:35.956] Device Firmware Version: 1.17.4877
[11:11:35.956] Device Serial Number: TA41g3Qb
[11:11:38.800] kernel get version
[11:11:39.017] interface close
[11:11:39.049] J2534 API Version: 04.04
[11:11:39.049] J2534 DLL Version: 1.02.4870 Feb 3 2017 23:36:31
[11:11:39.049] Device Firmware Version: 1.17.4877
[11:11:39.049] Device Serial Number: TA41g3Qb
[11:11:39.228] interface close
[11:11:39.272] J2534 API Version: 04.04
[11:11:39.272] J2534 DLL Version: 1.02.4870 Feb 3 2017 23:36:31
[11:11:39.272] Device Firmware Version: 1.17.4877
[11:11:39.272] Device Serial Number: TA41g3Qb
[11:11:39.455] SSM2 init
[11:11:39.616] SSM2 ECU ID is 4304594005
[11:11:41.640] interface close
[11:11:41.656] interface close
[11:29:27.424] using metadata XML ID read_sti05 from file C:/Program Files (x86)/OpenECU/EcuFlash/rommetadata/read templates/read_sti05.xml
[11:29:27.449] J2534 API Version: 04.04
[11:29:27.449] J2534 DLL Version: 1.02.4870 Feb 3 2017 23:36:31
[11:29:27.449] Device Firmware Version: 1.17.4877
[11:29:27.449] Device Serial Number: TA41g3Qb
[11:29:30.327] kernel get version
[11:29:30.542] interface close
[11:29:30.574] J2534 API Version: 04.04
[11:29:30.574] J2534 DLL Version: 1.02.4870 Feb 3 2017 23:36:31
[11:29:30.574] Device Firmware Version: 1.17.4877
[11:29:30.574] Device Serial Number: TA41g3Qb
[11:29:30.754] interface close
[11:29:30.792] J2534 API Version: 04.04
[11:29:30.792] J2534 DLL Version: 1.02.4870 Feb 3 2017 23:36:31
[11:29:30.792] Device Firmware Version: 1.17.4877
[11:29:30.793] Device Serial Number: TA41g3Qb
[11:29:30.977] SSM2 init
[11:29:31.137] SSM2 ECU ID is 4304594005
[11:29:33.151] interface close
[11:29:33.167] interface close
[11:30:20.796] using metadata XML ID read_sti05 from file C:/Program Files (x86)/OpenECU/EcuFlash/rommetadata/read templates/read_sti05.xml
[11:30:20.823] J2534 API Version: 04.04
[11:30:20.823] J2534 DLL Version: 1.02.4870 Feb 3 2017 23:36:31
[11:30:20.823] Device Firmware Version: 1.17.4877
[11:30:20.823] Device Serial Number: TA41g3Qb
[11:30:24.085] kernel get version
[11:30:24.289] interface close
[11:30:24.322] J2534 API Version: 04.04
[11:30:24.322] J2534 DLL Version: 1.02.4870 Feb 3 2017 23:36:31
[11:30:24.322] Device Firmware Version: 1.17.4877
[11:30:24.322] Device Serial Number: TA41g3Qb
[11:30:24.512] interface close
[11:30:24.556] J2534 API Version: 04.04
[11:30:24.556] J2534 DLL Version: 1.02.4870 Feb 3 2017 23:36:31
[11:30:24.556] Device Firmware Version: 1.17.4877
[11:30:24.556] Device Serial Number: TA41g3Qb
[11:30:24.739] SSM2 init
[11:30:24.899] SSM2 ECU ID is 4304594005
[11:30:26.916] interface close
[11:30:26.932] interface close
[11:59:37.046] using metadata XML ID read_sti05 from file C:/Program Files (x86)/OpenECU/EcuFlash/rommetadata/read templates/read_sti05.xml
[11:59:37.071] J2534 API Version: 04.04
[11:59:37.071] J2534 DLL Version: 1.02.4870 Feb 3 2017 23:36:31
[11:59:37.071] Device Firmware Version: 1.17.4877
[11:59:37.071] Device Serial Number: TA41g3Qb
[11:59:39.458] kernel get version
[11:59:39.675] interface close
[11:59:39.707] J2534 API Version: 04.04
[11:59:39.707] J2534 DLL Version: 1.02.4870 Feb 3 2017 23:36:31
[11:59:39.707] Device Firmware Version: 1.17.4877
[11:59:39.707] Device Serial Number: TA41g3Qb
[11:59:39.885] interface close
[11:59:39.927] J2534 API Version: 04.04
[11:59:39.927] J2534 DLL Version: 1.02.4870 Feb 3 2017 23:36:31
[11:59:39.927] Device Firmware Version: 1.17.4877
[11:59:39.927] Device Serial Number: TA41g3Qb
[11:59:40.113] SSM2 init
[11:59:40.531] SSM2 init
[11:59:40.949] SSM2 init
[11:59:41.369] SSM2 init
[11:59:41.789] SSM2 init
[11:59:42.212] SSM2 init
[11:59:42.630] SSM2 init
[11:59:43.051] SSM2 init
[11:59:43.470] SSM2 init
[11:59:43.889] SSM2 init
[11:59:44.417] interface close
[11:59:44.433] interface close
[12:03:35.035] using metadata XML ID read_sti05 from file C:/Program Files (x86)/OpenECU/EcuFlash/rommetadata/read templates/read_sti05.xml
[12:03:35.058] J2534 API Version: 04.04
[12:03:35.058] J2534 DLL Version: 1.02.4870 Feb 3 2017 23:36:31
[12:03:35.058] Device Firmware Version: 1.17.4877
[12:03:35.058] Device Serial Number: TA41g3Qb
[12:03:37.847] kernel get version
[12:03:38.050] interface close
[12:03:38.083] J2534 API Version: 04.04
[12:03:38.083] J2534 DLL Version: 1.02.4870 Feb 3 2017 23:36:31
[12:03:38.083] Device Firmware Version: 1.17.4877
[12:03:38.083] Device Serial Number: TA41g3Qb
[12:03:38.274] interface close
[12:03:38.315] J2534 API Version: 04.04
[12:03:38.315] J2534 DLL Version: 1.02.4870 Feb 3 2017 23:36:31
[12:03:38.315] Device Firmware Version: 1.17.4877
[12:03:38.315] Device Serial Number: TA41g3Qb
[12:03:38.498] SSM2 init
[12:03:38.659] SSM2 ECU ID is 4304594005
[12:03:40.685] interface close
[12:03:40.701] interface close
[12:05:51.328] using metadata XML ID read_sti05 from file C:/Program Files (x86)/OpenECU/EcuFlash/rommetadata/read templates/read_sti05.xml
[12:05:51.348] J2534 API Version: 04.04
[12:05:51.348] J2534 DLL Version: 1.02.4870 Feb 3 2017 23:36:31
[12:05:51.348] Device Firmware Version: 1.17.4877
[12:05:51.348] Device Serial Number: TA41g3Qb
[12:05:54.061] kernel get version
[12:05:54.278] interface close
[12:05:54.310] J2534 API Version: 04.04
[12:05:54.310] J2534 DLL Version: 1.02.4870 Feb 3 2017 23:36:31
[12:05:54.310] Device Firmware Version: 1.17.4877
[12:05:54.310] Device Serial Number: TA41g3Qb
[12:05:54.488] interface close
[12:05:54.528] J2534 API Version: 04.04
[12:05:54.528] J2534 DLL Version: 1.02.4870 Feb 3 2017 23:36:31
[12:05:54.528] Device Firmware Version: 1.17.4877
[12:05:54.528] Device Serial Number: TA41g3Qb
[12:05:54.698] SSM2 init
[12:05:54.858] SSM2 ECU ID is 4304594005
[12:05:56.874] interface close
[12:05:56.889] interface close
[12:07:44.540] using metadata XML ID read_sti05 from file C:/Program Files (x86)/OpenECU/EcuFlash/rommetadata/read templates/read_sti05.xml
[12:07:44.563] J2534 API Version: 04.04
[12:07:44.563] J2534 DLL Version: 1.02.4870 Feb 3 2017 23:36:31
[12:07:44.563] Device Firmware Version: 1.17.4877
[12:07:44.563] Device Serial Number: TA41g3Qb
[12:07:54.674] kernel get version
[12:07:54.891] interface close
[12:07:54.923] J2534 API Version: 04.04
[12:07:54.923] J2534 DLL Version: 1.02.4870 Feb 3 2017 23:36:31
[12:07:54.923] Device Firmware Version: 1.17.4877
[12:07:54.923] Device Serial Number: TA41g3Qb
[12:07:55.102] interface close
[12:07:55.139] J2534 API Version: 04.04
[12:07:55.139] J2534 DLL Version: 1.02.4870 Feb 3 2017 23:36:31
[12:07:55.139] Device Firmware Version: 1.17.4877
[12:07:55.139] Device Serial Number: TA41g3Qb
[12:07:55.326] SSM2 init
[12:07:55.744] SSM2 init
[12:07:56.163] SSM2 init
[12:07:56.324] SSM2 ECU ID is 4304594005
[12:07:58.348] interface close
[12:07:58.363] interface close
[12:08:03.154] using metadata XML ID read_sti05 from file C:/Program Files (x86)/OpenECU/EcuFlash/rommetadata/read templates/read_sti05.xml
[12:08:03.167] J2534 API Version: 04.04
[12:08:03.167] J2534 DLL Version: 1.02.4870 Feb 3 2017 23:36:31
[12:08:03.167] Device Firmware Version: 1.17.4877
[12:08:03.167] Device Serial Number: TA41g3Qb
[12:08:04.880] kernel get version
[12:08:05.098] interface close
[12:08:05.130] J2534 API Version: 04.04
[12:08:05.130] J2534 DLL Version: 1.02.4870 Feb 3 2017 23:36:31
[12:08:05.130] Device Firmware Version: 1.17.4877
[12:08:05.130] Device Serial Number: TA41g3Qb
[12:08:05.307] interface close
[12:08:05.333] J2534 API Version: 04.04
[12:08:05.333] J2534 DLL Version: 1.02.4870 Feb 3 2017 23:36:31
[12:08:05.333] Device Firmware Version: 1.17.4877
[12:08:05.333] Device Serial Number: TA41g3Qb
[12:08:05.516] SSM2 init
[12:08:05.677] SSM2 ECU ID is 4304594005
[12:08:07.703] interface close
[12:08:07.719] interface close
[12:08:18.142] J2534 API Version: 04.04
[12:08:18.142] J2534 DLL Version: 1.02.4870 Feb 3 2017 23:36:31
[12:08:18.142] Device Firmware Version: 1.17.4877
[12:08:18.142] Device Serial Number: TA41g3Qb
[12:08:28.402] sending bit rate sync bytes...
[12:08:30.268] no bit rate adjust response
[12:08:30.268] interface close
[12:08:38.347] using metadata XML ID read_sti05 from file C:/Program Files (x86)/OpenECU/EcuFlash/rommetadata/read templates/read_sti05.xml
[12:08:38.362] J2534 API Version: 04.04
[12:08:38.362] J2534 DLL Version: 1.02.4870 Feb 3 2017 23:36:31
[12:08:38.362] Device Firmware Version: 1.17.4877
[12:08:38.362] Device Serial Number: TA41g3Qb
[12:08:40.807] kernel get version
[12:08:41.022] interface close
[12:08:41.054] J2534 API Version: 04.04
[12:08:41.054] J2534 DLL Version: 1.02.4870 Feb 3 2017 23:36:31
[12:08:41.054] Device Firmware Version: 1.17.4877
[12:08:41.054] Device Serial Number: TA41g3Qb
[12:08:41.235] interface close
[12:08:41.270] J2534 API Version: 04.04
[12:08:41.270] J2534 DLL Version: 1.02.4870 Feb 3 2017 23:36:31
[12:08:41.270] Device Firmware Version: 1.17.4877
[12:08:41.270] Device Serial Number: TA41g3Qb
[12:08:41.454] SSM2 init
[12:08:41.614] SSM2 ECU ID is 4304594005
[12:08:43.641] interface close
[12:08:43.657] interface close
[12:11:52.103] using metadata XML ID read_wrx02 from file C:/Program Files (x86)/OpenECU/EcuFlash/rommetadata/read templates/read_wrx02.xml
[12:11:52.109] using metadata XML ID read_wrx02 from file C:/Program Files (x86)/OpenECU/EcuFlash/rommetadata/read templates/read_wrx02.xml
[12:12:03.415] using metadata XML ID read_wrx02 from file C:/Program Files (x86)/OpenECU/EcuFlash/rommetadata/read templates/read_wrx02.xml
[12:12:04.848] using metadata XML ID read_wrx02 from file C:/Program Files (x86)/OpenECU/EcuFlash/rommetadata/read templates/read_wrx02.xml
[12:12:04.862] J2534 API Version: 04.04
[12:12:04.862] J2534 DLL Version: 1.02.4870 Feb 3 2017 23:36:31
[12:12:04.862] Device Firmware Version: 1.17.4877
[12:12:04.862] Device Serial Number: TA41g3Qb
[12:12:10.425] denso02_bootloader_cmd_start
[12:12:11.665] denso02_bootloader_cmd_start
[12:12:12.911] denso02_bootloader_cmd_start
[12:12:14.183] denso02_bootloader_cmd_start
[12:12:15.428] denso02_bootloader_cmd_start
[12:12:15.851] kernel get version
[12:12:16.177] interface close
[12:12:16.189] interface close
[12:12:39.704] using metadata XML ID read_wrx02 from file C:/Program Files (x86)/OpenECU/EcuFlash/rommetadata/read templates/read_wrx02.xml
[12:12:39.719] J2534 API Version: 04.04
[12:12:39.719] J2534 DLL Version: 1.02.4870 Feb 3 2017 23:36:31
[12:12:39.719] Device Firmware Version: 1.17.4877
[12:12:39.719] Device Serial Number: TA41g3Qb
[12:12:53.837] denso02_bootloader_cmd_start
[12:12:55.087] denso02_bootloader_cmd_start
[12:12:56.337] denso02_bootloader_cmd_start
[12:12:57.578] denso02_bootloader_cmd_start
[12:12:58.823] denso02_bootloader_cmd_start
[12:12:59.248] kernel get version
[12:12:59.575] interface close
[12:12:59.588] interface close
[12:13:21.453] using metadata XML ID read_wrx04 from file C:/Program Files (x86)/OpenECU/EcuFlash/rommetadata/read templates/read_wrx04.xml
[12:13:21.460] using metadata XML ID read_wrx04 from file C:/Program Files (x86)/OpenECU/EcuFlash/rommetadata/read templates/read_wrx04.xml
[12:13:22.984] using metadata XML ID read_wrx04 from file C:/Program Files (x86)/OpenECU/EcuFlash/rommetadata/read templates/read_wrx04.xml
[12:13:23.010] J2534 API Version: 04.04
[12:13:23.010] J2534 DLL Version: 1.02.4870 Feb 3 2017 23:36:31
[12:13:23.010] Device Firmware Version: 1.17.4877
[12:13:23.010] Device Serial Number: TA41g3Qb
[12:13:29.352] kernel get version
[12:13:29.555] interface close
[12:13:29.586] J2534 API Version: 04.04
[12:13:29.587] J2534 DLL Version: 1.02.4870 Feb 3 2017 23:36:31
[12:13:29.587] Device Firmware Version: 1.17.4877
[12:13:29.587] Device Serial Number: TA41g3Qb
[12:13:29.780] interface close
[12:13:29.819] J2534 API Version: 04.04
[12:13:29.819] J2534 DLL Version: 1.02.4870 Feb 3 2017 23:36:31
[12:13:29.819] Device Firmware Version: 1.17.4877
[12:13:29.819] Device Serial Number: TA41g3Qb
[12:13:29.991] SSM2 init
[12:13:30.152] SSM2 ECU ID is 4304594005
[12:13:32.181] interface close
[12:13:32.196] interface close
[12:13:39.176] using metadata XML ID read_wrx04 from file C:/Program Files (x86)/OpenECU/EcuFlash/rommetadata/read templates/read_wrx04.xml
[12:13:39.203] J2534 API Version: 04.04
[12:13:39.203] J2534 DLL Version: 1.02.4870 Feb 3 2017 23:36:31
[12:13:39.203] Device Firmware Version: 1.17.4877
[12:13:39.203] Device Serial Number: TA41g3Qb
[12:13:41.606] kernel get version
[12:13:41.823] interface close
[12:13:41.856] J2534 API Version: 04.04
[12:13:41.856] J2534 DLL Version: 1.02.4870 Feb 3 2017 23:36:31
[12:13:41.856] Device Firmware Version: 1.17.4877
[12:13:41.856] Device Serial Number: TA41g3Qb
[12:13:42.035] interface close
[12:13:42.073] J2534 API Version: 04.04
[12:13:42.073] J2534 DLL Version: 1.02.4870 Feb 3 2017 23:36:31
[12:13:42.073] Device Firmware Version: 1.17.4877
[12:13:42.073] Device Serial Number: TA41g3Qb
[12:13:42.259] SSM2 init
[12:13:42.419] SSM2 ECU ID is 4304594005
[12:13:44.447] interface close
[12:13:44.448] interface close
[12:22:08.017] using metadata XML ID read_wrx04 from file C:/Program Files (x86)/OpenECU/EcuFlash/rommetadata/read templates/read_wrx04.xml
[12:22:08.038] J2534 API Version: 04.04
[12:22:08.038] J2534 DLL Version: 1.02.4870 Feb 3 2017 23:36:31
[12:22:08.038] Device Firmware Version: 1.17.4877
[12:22:08.038] Device Serial Number: TA41g3Qb
[12:22:21.486] kernel get version
[12:22:21.689] interface close
[12:22:21.721] J2534 API Version: 04.04
[12:22:21.721] J2534 DLL Version: 1.02.4870 Feb 3 2017 23:36:31
[12:22:21.721] Device Firmware Version: 1.17.4877
[12:22:21.721] Device Serial Number: TA41g3Qb
[12:22:21.914] interface close
[12:22:21.955] J2534 API Version: 04.04
[12:22:21.955] J2534 DLL Version: 1.02.4870 Feb 3 2017 23:36:31
[12:22:21.955] Device Firmware Version: 1.17.4877
[12:22:21.955] Device Serial Number: TA41g3Qb
[12:22:22.139] SSM2 init
[12:22:22.299] SSM2 ECU ID is 4304594005
[12:22:24.321] interface close
[12:22:24.337] interface close
