Cant build boost
Off Topic Discussion
96 Eclipse with an older 16g turbo (internal gate). Only making 7lbs of boost. I have version 3 ECMlink and no matter what Ive done I cant get more than 7lbs. Thought it may be something wrong with the ECM not activating the 3 port Mac Valve solenoid so I wired it temporarily where its activated all the time. I should be building boost to the moon as far as I understand but even with that I barely get 10lbs. Does anyone smarter than me think this is an actuator issue or something else like the internal gate not closing off? Visually everything looks ok....I am out of ideas other than to start throwing expensive parts at this thing.
It totally depends on what the (I'm assuming stock) internal wastegate actuator is sprung too. Traditionally, the rule of thumb is that you can boost to double what your wastegate is sprung to with boost control. Recently tuned a Miata sprung to 5 psi, and we barely got 10 out of it with boost control.
