LS conversion Tremec Reverse Lockout
Off Topic Discussion
I'm Installing a LS 6.0ltr engine and Tremec 6 speed into a LH/X Torana with the VE Commodore ECU and Harness, deleting the Body control module
The wiring is almost complete except for a few minor details
My Questions
Does the Reverse lockout require the clutch signal to operate or just a low road speed of less than 5Kph?
I will need to install new resisters into the circuit to replace the Terminating resistors from the Low and High-speed CanBus, some insight or direction would be helpful.
I have been undertaking the wiring and CanbUs courses and will review them, However, I need to complete this job ASAP and some quick advice would be helpful.
Please note I am well qualified in the above task just have never had to deal with Canbus until recently. Bit of a learning curve but nothing to scary.
