Analog Tach input on PMU-16
Is it possible to the use tach output from an MSD 6al-2 as a tach input on a PMU-16?
No the input pins can only do voltage measurement not frequency measurement
I used a tachometric relay to act as an input to the PMU-16. This can be used as an engine running or cranking signal. RPM is not really feasible.
