Working through your example it shows setup of Enabled power through CAN Bus and and CAN Button, I'm struggling to work out the function for Enabled Power if one used a traditional key barrel ignition or (in my case a push button which has replaced the ignition barrel using the existing wiring) , I don't want to use CAN as a start option for my current setup .
Do you have some examples or notes how to set this up?
Thanks
Tony
