Crank sensor pin out
Practical 3D Printing
Discussion and questions related to the course Practical 3D Printing
Hello I am wiring a Ecu master emu classic into a Vauxhall and I have got a bosch 0 261 210 030 crank sensor that is going in the Vauxhall c20 but I can’t find a pin out for the sensor so I can wire it up so any help would be amazing thank you
It looks like that's from a Saab 900, I would look for factory wiring diagrams if you can figure out what years used that part. If that's an OEM Vauxhall part, then look it it's factory workshop manual.
Got a Haynes Calibra manual and it "should" be #1 12V (supply), #2 signal, #3 ground.
Page 12.29 and it's designated P35, 2/3rds down on right side, if you have access to one to double check.
Thank you for the info I will try that and see how I get on
