Small Misfire m42 bmw turbo
Practical 3D Printing
Discussion and questions related to the course Practical 3D Printing
We had setting the engine until 0.7 pressure. When we try 0.9 we have some small misfire, and I can see a little flames from the external on the hood. Also, on the datalog I see that the dwell on boost is unstable from 2.7-3.3, which I set up to 2.7ms on 13.8V. We use stock spark plug from this engine m42b18. Is this the reason for misfire, or it is possible a overheat coil or something other?
Any opinion on that ?
Often "Dwell scatter" is an indication you have a trigger problem. I would start by investigating the trigger waveform first, make sure polarity is correct etc.
