Shielded Cable vs Foiled
Practical 3D Scanning
Discussion and questions related to the course Practical 3D Scanning
Is it acceptable to use foiled cables (like the ones used on nmea 2000 and can bus networks) for cam/crank sensors and knock ?
Shields can be foil or braid. I would look carefully at the temperature rating of the insulation when choosing a shielded cable. The foil shield will normally have an uninsulated stranded wire that gives you a way to connect with the shield.
Wil take a look at the temp specs of the cable.
Thank you
