How can I calculate the corner radius of any curve? And what value is it represented by?
A radius is half the diameter of a circle. It represents the distance from the center of the circle to a point on the circle. For an arc (part of a circle), there are various mathematical methods to calculate the radius using measurements.
But first...
Do you mean a curve on the road, or a curve on bodywork or some mechanical component? So you think it a constant radius or changing? What measurement tools do you have?
