Hey everyone. In this video, Andre mentions that you can adjust toe in the 86 without jacking up the car. How is this done? Thank you!
I often adjust front toe with all 4 wheels on the ground. just reach behind the wheel well and adjust the steering tie rod / lock nut as normal. you will need the wheels on turn tables or "slip plates".
