Any short-cuts/Tips for Setting UP VCM Scanner for a 2019 L5P Duramax?
Practical Diesel Tuning
So I'm the (proud? - probably not) new owner of a new-to-me 2019 GMC 2500HD with the L5P Duramax/"Real" Allison 6 speed auto. It's my first Diesel of any kind - so be nice to me - I know some theory, but nothing practical - and I've done just enough HP Tuners hacking on Gen III/IV LS gas engines to be dangerous.
So... I know this truck was been tuned, and I knew my antique MPVI Version 1.0 wasn't going to read it - so did the HPT trade-in program - and now own an MPVI4. (Yay - the 1.0 was about to be end of life anyway). I bought my 6! credits - and was able to download/modify the ECU file (the Allison TCU didn't come up as a READ option - but I've read it takes another 4? credits to unlock it, no need for the moment, allegedly the TCM has been tuned as well)
I have been successfully edited the file that's in it - and modified the Speedo Revs/Mile value so that speedo now seems to match my GPS speed - tire size is 275/65 not 265/60 as it should be.
Now - I'd like to just drive around and monitor using VCM scanner - but my old LS Gas scanner setup is in no way useful. Is there an ?Easy? way to reconfigure the scanner to read the important/proper Duramax parameters?
So far, AI has provided cryptic advice about opening the tune file in Editor, then opening Scanner - and somehow Scanner will "know" what parameters to use? Haven't tried that yet - but seems unlikely. I have done the "repoll for supported parameters" while connected to the truck, then gone thru the Add Channel procedure, grabbing the common diesel channels - but I've just got an ugly disorganized list of parameters - and the charts & gauges are still the old LS Gas channels.
I'm a VIP member - so I searched all the webinars and didn't find a specific "How to Use VCM scanner" topic - AND - I didn't seem to find it in the Practical EFI or Diesel tuning classes either... What am I missing?
Maybe this is just a plea for someone to send me a "CPT" file for a scanner already set up for Duramax 6.6L (L5P if those are special). I would be forever grateful...
This tune is definitely NOT stock - as it has a 5 level SOTF (switch on the fly?) functionality (thru the cruise button) built into it. I haven't done all my research but that appears to require some kind of special OS and/or WinOLS magic that is beyond me. No matter - I just want to log some channels while I figure out how this thing runs without spark plugs and makes wooshy-wooshy VNT turbo noises.
THANKS MUCH IN ADVANCE FOR ANY GUIDANCE (OR PITY)
Jim
PS - it has 217K miles on it - so I got it cheap. I'm sure that won't come back to bite me, right?
They cover VCM scanner setup in many of the worked examples for EFI tuning, but now we need a worked example for newer Chevy and Dodge diesel trucks in the Diesel tuning course!
In the mean time, have you looked on the HPTuners forum (HP Tuners Bulletin Board), sometimes you can find info for VCM scanner setup for your vehicle/ECU.
Yeah thanks - I was going to work my way thru the Reflash EFI worked examples to pick up what I can on VCM scanner setup. I did troll the HP Tuners Duramax Forum a bit - but there's not much out there - or I suck at using the correct search terms. I've had better luck using Google AI - which has pointed me to some of the HP Tuners YouTube webinars about scanner setup - of course none of their examples cover a Duramax Diesel.
I did find one scanner config file - it's from a Diesel Tuning place's webpage - they walk you thru a scanner setup - so a customer can pull a datalog and email it back to them for troubleshooting of the tune:
https://knowledge.duramaxtuner.com/knowledge/how-to-data-log-an-l5p-with-hp-tuners
This seems to have a decent channel list - but I could still use help of which parameters should be grouped and graphed together. Maybe that will be more apparent after I work thru the Practical Diesel course.
In general, the 2017+ L5P Duramax tuning world is pretty tight lipped on the forums I've found. I'm sure some of it is the "we can't help you with a Delete tune nonsense" - but general discussion of the 5 Level SOTF tunes seems pretty limited. I suspect the "Delete Pirates" have their own forums where these subjects are covered.
I know everyone was running scared after all the high profile EPA prosecutions of the high volume/social media delete places - but I think a lot of this got overblown. I think a lot of people use their 2500/3500 diesel trucks to run a small business - and they just want reliability after all the aftertreatment stuff starts failing and starting the doomsday clock on their dash. I'm sure 99.9% of them have no interest in Rolling Coal on Instagram- they just want a truck that starts and drives 70MPH without throwing a light show on the dash.
