Bosch me7 ecu connector terminals
Practical Engine Building
Anyone have the part number for the terminals used on the Bosch me7 ecu connector?
it’s the 81 and 40 pin connectors, I believe they are tyco brand, but I’ve looked everywhere and can’t seem to locate the terminals I need.
photo of connector attached
thanks!
That looks like the connectors (81+40) used on the MBE 9A9 ECU. I have a brand new connector set I would sell if you would like to see if it will work with your Bosch ECU. Just send me an email, ferg@veracitydata.com
Hello, for those connectors the terminals are a proprietery Bosch article named BMK 0.6.
The Bosch part number for 0.35 - 0.5 mm2 is 1 928 498 000 and for 0.5 - 0.75 mm2 is 1 928 498 001.
There are also BMK 0.6-D terminals which are box shaped. However, as far as I am aware they are not meant for the 40+81 connectors. I have added a pdf with a technical assembly drawing for reference as well.
Hopefully this helps.
  • A928000321-DEEN-AGZ-001-004-23-1-SAP-Status-40-Labor-F15-Change-92J14477.pdf
If it really is a BMK 0.6 series, those are available from Ballenger Motorsports in the USA:
https://www.bmotorsports.com/shop/product_info.php/products_id/2245
