I there,
I need to build a Swirl Pot/Fuel Surge Tank with internal fuel pump...so, anyone have a suggestion for how to pass the wire/cable from external thought the swirl for power up the pump?
I look around the web, but I can't find something good for me...
Thanks to All
Fabry
I researched this a few months back for a customer of mine. Here's what I found in the USA:
http://fuelsafe.com/store/fuel-cell-parts/fuel-cell-wire-harness/wh04f2.html
and either this:
http://fuelsafe.com/store/fuel-cell-parts/fuel-cell-wire-harness/wh04m2-844.html
or this:
http://fuelsafe.com/store/fuel-cell-parts/fuel-cell-wire-harness/wh04m2.html
Summit Racing also has a simple wire pass-through that might be all you need (US$24):
I went through this a couple of months back with our 86. I ended up purchasing the parts from Radium Engineering in the US: https://www.radiumauto.com/Bulkhead-Fuel-Pump-Harness-Assemblies-P682.aspx
Here is another simple and effective one:
https://www.efihardware.com/products/1593/submersible-pump-bulk-head-terminals
Hi All,
sorry for this big delay...thanks for all the links and suggestion!!!
Maybe I've find a way for my problem, still waiting the parts needed for realize my idea, and then I will show you the project!
