I am looking for a safe coil dwell table for a Toyota 86 with factory coils...perhaps from a Motec M150 86 calibration or ECUTek. What I currently have is attached is from an 86 race car. I just want to double check them against a factory or Motec derived dwell table.
I see this in a MoTeC Toyota 86 pkg:
Voltage, Charge Time (ms)
8.0, 5.3
9.0, 4.3
10.0, 3.6
11.0, 3.0
12.0, 2.6
13.0, 2.3
14.0, 2.1
15.0, 1.9
Hope that helps.
Thanks!
I am using 2.8-3 ms at 14 v
Its been amazing
I would be careful at using these coils at that dwell time and voltage, the MoTeC Dwell tables are done to a point that is approx 90% the coil saturation limit (to allow for variances in coils) so running the numbers higher means that you are just saturating the coil and generating heat that isn't needed.
