NTC thermistor calculator to generate voltages for a resistance calibration curve
Ballenger Motorsports offers a range of temperature sensors and sensors that include NTC thermistors. As a result, we get questions about how to calculate the voltages for a given sensor in a given installation. So, we've launched a tool to help you calculate your temperature sensor voltage values for data systems or use with your ECU. Presets are included for temperature sensors we offer. You can also input your own custom data set for any thermistor.
This utility will give you the voltage and temperature data points to match your application, taking into account the pull-up and/or pull-down resistor value and supply voltage to give you an accurate data table and chart plot.
https://www.bmotorsports.com/shop/static.php/post/tempcalc?xrf=hpa
Love your products! I've been a customer for years.
