Decided to log my 2007 g3 wrx this morning. The vehicle runs a stock file and notice the feedback know at -5.62. Using ecuflash and megalog veiwer hd. Check the log and nothing is realy pointing to why. Max rpm would have been 3500rpm max. Is there any advice on what i should be looking out for in the data log. Fuel trims looked great in the histogram. Any advice would be appreciated.
What happens if you reduce the timing (or increase the fuel) in the area indicating knock? Does it go away? If not, then perhaps it's "false knock" and just a noisy spot where the engine's mechanical parts resonate at the same frequency as knock.
Engine load 1.020
Rpm 2172
feedback knock -5.620
Throttle angle 20.780
Air flow 2.500
Mass air flow sensor 38.130
Manifold relative pressure -1.600
A/f correction 1.560
VVE 2.5ltr 81.68
A/f learning -4.690
Injector latency 0.811
Injector pulse width 6.140
Boost error 3.320
Batt v 13.90v
Igniton base timing 22.40
Igniton total timing 22.50
Final fueling 13.430
Intake air temp 88.00
If I had to guess from that, the A/f learning seems like it might be removing fuel. Perhaps you should disconnect the battery and force he ECU to re-learn. You might have a bad (or fouled) O2 sensor. If that intake air temp is in C, is it real (you are in vacuum)? Perhaps that has become disconnected or needs replacement.
The ECU use a stock file but is your WRX Stock? Sometimes when you snap the throttle at low-ish RPM (like 2000rpm), the piston slap on the wall of the cylinder and the knock sensor pick it up. It usually remove 1.4 or 2.8 deg from my experience. Were there any Fine Learning Knock Correction? Did the IAM stayed at 1.000?
It's hard to guess from just a snapshot of the log, if you can post your CSV log from RomRaider Logger, it's gonna be easier for us to help you!
Also, you can reset the ECU and trims from RomRaider Logger.
Data log 23-2-23 and rom file
