Opel Omega C20LET swapped
Race Driving Fundamentals
Here is my 1992 Opel Omega with C20LET from a Calibra
Build is as follows:
Head:
Mild port
Crower lash caps
XE camshafts
Block:
JE 86.5mm 8.5:1 Pistons
Crower H-rods
Z20let oil pump
Oil squirters
Semi grout filled
ARP main studs
ARP head studs
Modified oilpan
Bolt ons:
Garrett GT3582R
PeterG Exhaust manifold
Billet intake
Bosch Motorsport injectors 1200cc
Big FMIC
Tial Wastegate and Bov
Electromotive TecGT
Drivetrain:
E34 M5 diff 3.91 ratio
E9x M3 gearbox (GS6-53BZ)
Spec Custom sinter clutch
Sachs Performance pressure plate
Lotus Omega axles
Custom 1 piece driveshaft from GKN
Subframes and brakes from Omega 3000
Suspension:
AP racing springs
Koni Shocks
Interior:
EVO500 interior
SPA design gauges
Car makes:
466 hp @7000rpm
600 nm @5000rpm (442ft lbs)
Car weighs 1275kg (2810lbs)
Everything is approved by the Norwegian Public Roads Administration.
So the car is fully road legal here in Norway :)
Would like to get som suggestions on further improvements.
Been looking at MaxxEcu and more modern turbo.
- Aksel
As a guy from the states that grew up in love with touring car racing in Europe this is very cool. I would be running around like I was Tommy Rustad loving life. nice build
What is the red car at first, I thought it was a Datsun 510. But I was wondering if it is an older Toyota after looking at it more, maybe a Corona?
Thanks!
The red car is my friends mx30 cressida
18RG swap, TRD supra diff, T3 suspension
He has 4 of them, all in different conditions
Little update!
Started taking the club level wiring course and plan on buying a Maxxecu Sport and making the harness for it.
Have also been looking at turbo's, mainly G30-660 and GTX3071r Gen 2.
Aim is ~ 400-450whp on 98 octane
Suggestions are more than welcome :)
Cool build!
It's been quite a while but IIRC, the XE cam' swap was just the intake with it retarded 7 degrees (that little change in timing was good for over 50hp, IIRC), using both the overlap killed power, especially bottom end, as it bled off boost. Might be a good idea to double check that as it could be a simple upgrade?
Thanks!
Dont quite understand what you mean about "using both"....
Are you talking about using one XE cam and one LET cam?
Or am I totally misunderstanding?
LET exhaust on stock marks, XE inlet retarded 7 degrees. It looks like you're using XE inlet and exhaust which, IIRC, lost significant power/torque over the former.
Your setup might work better for your full setup, though - have you experimented with any other combinations or timing?
Back in the day, goodness this is over 15 years ago - time does fly, there were some VERY smart guys from your part of the world with 4WD Calibras, and the Brazilians are also pushing the basic LET/XE engines to ever higher power levels!
