help
Practical Reflash Tuning
I have a 2016 Honda CRZ with Sprintex Supercharger. It seems to have reached a limit on the max pulsewidth that increasing fuel and air does not affect? It's been fitted with 270cc injectors (I think stock was 180cc) I believe I am using the correct Deadtime and AFM Fuel Table. PW just seems to flatline during boost.
The Duty Cycle is not maxed out it gets around 40-50%. I have heard this might be a constraint of the ECU seeing unplausible data that it normally wouldn't see as an N/A Engine. Can anyone Shed some light? How do I trick the ECU into working? Been messing with this for months and little to no results.
I had previously been using 550cc Injectors and also tried 410cc, and I was having the opposite problem. I could not get the fuel at idle below a certain pulsewidth. I downgraded to 270 to see if I could make it work better, as I know others with the same Car have been successful but for older years.
The only levers I have to work with are the AFM Fuel Table and the MAF Curve. The trims aren't real bad until you hit boost, it goes open loop and very lean.
If by some chance it does stay closed loop during boost it will still be lean but the pulsewidth does seem to actually react and not just flatline or fall off a cliff. really need help here. Watched all the Videos nothing seems to be helping. I have also tried enriching the WOT targets to way beyond my target. Its commanding the fuel, but im not getting it. The WOT is based on MAP pressure.
I have the stock intake on, and used the MAF curve from the Stock Calibration, when it hits boost I tried increasing airflow from that point smoothly but it isnt working. There is no injector scaling available, just deadtimes and AFM Fuel.
trying to post screenshots
AFM Fuel and MAF
No one has any advice?
Hi Stephen, this isn't a software I'm familiar with sorry. It's possible there is a hard coded limit to the injector pulsewidth however that would be somewhat unusual. I'd contact K Tuner (that's what it appears you're using) and see if they can provide more specific advice as they will know their product the best.
Thank you Andre I greatly appreciate the response.
when closed loop intervenes it overcomes that limit but is still very lean. Ktuner previously had told me that reindexing the columns from:
STOCK= 131mbar/236mbar/302mbar/526mbar/657mbar/789mbar/855mbar/670mbar/0.2(psi)
into:
MODIFIED: 131mbar/236mbar/302mbar/394mbar/526mbar/657mbar/920mbar/2.5psi/6.3psi/9.2psi
Their response was:
"As you’ll note there was no factory boost basemap to start from and you altered the headings yourself. Fuel will be clamped. Ignition won’t."
So I took that as the WOT Enrichment tables will be clamped at 920mbar, so I set my targets there, AFR.CMD followed that, but I'm wondering
if could be causing a problem with the Enrichment. Unfortunately all of the tables such as the ignition and fuel are tied together so if I change
the headers for the ignition the fuel table is tied to those headers as well, and there is no ability to add additional columns.
Maybe the reindexing isn't the problem but it's something I thought of, maybe a bug in Software, I'm not sure.
