Histogram set up
Practical Reflash Tuning
Hay all
On the worked example for the sd tune can someone give me a screenshot of the histogram layout for the EQerrSD. I can seem to figure it out because I can't get it to log correctly.
Thanks for the help
Hi Tommy, no problem. I've attached a screenshot of the setup. Remember to grab the axis labels for both row and column from your actual SD table so that they match in the editor and scanner. Depending on the PCM you're tuning you may need to also swap the column and row axis headers. This is as simple as clicking on the parameter and selecting the relevant parameter to match your SD table.
Thank you this is perfect
