Neural Network Trainer - Dodge Intake & Cam Variables
Practical Reflash Tuning
Relevant Module: Worked Examples > HP Tuners Dodge - 5.7L Hemi ANN Tuning > Step 4: MAF/Injector Scaling
After watching the courses, it appears that with the Dodge engines, the single cam makes it such that there is generally only 5 scenarios/mixtures of cam intake and exhaust angles and that they should all equal the same LSA totals. Example in the training is that all combinations are 228.5 degrees of separation.
However, when i create th NNT file for my 2022 Ram 2500 6.4 Hemi, I get the following values for intake and exhaust and these combinations wont combine as in the training (i.e. the 228.5 degrees of separation).
Intake 93, 105, 117, 129, 141
Exhaust 93, 102.5, 112, 121.5, 131
When I am logging in the scanner, the Cam Center positions always sum to 234 degrees.
Is this unusual? It makes the data overlap and confusing when attempting to train using the NNT. i.e would i ever use the intake 93 and exhaust 131 scenario because that wouldn't be 234 degrees of separation?
