Reversions influence on Lambda
Practical Reflash Tuning
Relevant Module: Worked Examples > HP Tuners GM Gen III/IV LS - Basic > Step 4: MAF/Injector Scaling
At idle, if you have a larger cam, what's the % of a normal swing to the lambda #? For example, at idle say 850rpm, if you're targeting 1.0 lambda ... and you're swinging lean for reversion, what's a normal % 1.0 to 1.1 - 1.15? or? Thanks!
