Increasing clutch pressure on DQ500 gearbox
Road Tuning
Hello,
I am tying to raise clutch pressures on a DQ500 gearbox to meet specified target values (17 bars). I am using the ECM Titanium software with identified mappack. The VCDS logs show that the specified clutch pressure is 13 bars and the actual pressure is also 13 bars.
Appreciate if anyone has been diving in TEMIC TCU tune and could help on this matter
I don't have experience with that in particular, but there's generally clutch pressure target and limit tables, so just make sure a limit table isn't impeding you. If you set a target higher than a limit, generally the target value the ECU runs will never exceed the limit value.
