need help finding the correct connector. webinar 398 ?
Webinar Questions
i am trying to find the connector that matches this throttle body i had in a box of "junk". all the internet searches say they found the correct one, but it always has a staggered pin layout. even the datasheets. this one is two straight stacked rows as seen in the picture.
audi 077133062A
bosch 0280750047
It looks like the same connector that is used for the LSU4.9 sensors. The sensors do not have staggered pin layouts. Also note that between all of these retailers, the connectors are not all the same. Some use the Micro Timer II terminals and other are had with the AMP/TE MCP termainal type. The terminals are specific to the connectors. Some people have a preference here.
https://www.corsa-technic.com/item.php?item_id=1296&category_id=263&manufacturer_id=54
https://www.prowireusa.com/p-3731-lsu-49-connector-kit.html
https://racespeconline.com/collections/connector-kits/products/honda-connector-7
https://www.ksvlooms.com/products/bosch-lsu-4-9-connector-kit
https://www.milspecwiring.com/Bosch-LSU-49-Lambda-Sensor-Connector-Kit_p_497.html
https://www.bmotorsports.com/shop/product_info.php/products_id/2081
thank you very much.
i just happen to have a wb with the 4.9 sitting here on the desk and have verified it does in fact match up.
