Freeze Plug Sealant
Wheel and Tyre Fitment Course
Discussion and questions related to the course Wheel and Tyre Fitment Course
Probably over thinking it but what do people use to seal freeze plugs (or welch Plug if you prefer)?
i am looking at loctite 510 as its rated to 200'c, has excellent glycol/water Resistance. it sets rigid.
That should work fine, doing some on-line checking of what people use has quite a variety of sealants and several who use none. I expect if you got 20 replies to this, you could get 20 different products used.
As a 'prentice, many years ago, we mixed up some gunk (can't recall the name, but it was a mix of a yellow powder and glycerine) for this.
Personally, now I use shellac with, where possible, brass plugs or brass plated steel if those weren't available.
Thanks Gord
it seems its a very opinion based topic, i will try shellac with stainless plugs. hopefully that will keep corrosion at bay.
