TXL vs GXL wire flexibility
Variable Cam Control Tuning
Hi
Can anyone with real world experience tell me if there is a discernible difference in flexibility between TXL and GXL wire?
I was looking at using 16 awg wire for a chassis harness and matching the OEM colour striping but it seems that 16 awg TXL is primarily sold in solid colours whereas there are more options to get GXL wire with stripes.
From my research it seems the only difference between the two is insulation thickness and thus flexibility.
Regards
Adam
I can't answer your question as I stick to Tefzel, but in case this does help...
Striped Tefzel is readily available here if you don't have a local source:
https://www.prowireusa.com/m22759-16-tefzel-wire.html
