Potentiometer control
CAN Bus Communications Decoded
Wanting do a electric power steering pump conversion on my e36 using the dodge pump however a hangtight.io controller is 429.99( which is 1,160.97 dollars in my currency). However reform motorsports offers a controller that uses the potentiometer dial the car is getting a standalone controller so can I cut off the dial and pin it into my standalone and use a table to adjust it ? Is that a reasonable solution?
