Looking for 3 Pin Sensor Connector #
Data Analysis Fundamentals
Hey all, I'm looking to make up some 3 Pin Pressure Sensor extension harnesses for the Stainless Pressure sensors by all the common brands. I've found the typical harness-side connector but I'm having a hard time finding its mating connector (outside of the sensor itself).
Here is a sample of what I'm looking to make -
https://www.summitracing.com/parts/icb-wetps30-24?seid=srese1&gclid=CjwKCAiArY2fBhB9EiwAWqHK6ptWHn9Aomn41WM2AgsEbHZp30GXof8HdYeggtMQ5uQggRITaqV-jBoCkWsQAvD_BwE
If anyone has a part number available that would be a huge help. I have tried searchig Digikey and Mouser with no luck.
Thanks!
Use a connector you can get to make your extension. I don't think those connectors are available as a cable connection. Those connectors come from Delphi Packard, but they are now known as Aptiv. Here is their website, with the GT 150 series 3-way connector that are available:
Aptiv GT 150 3-way connectors
We have some pre-made harness here that already have the end terminated with the connector. I was hoping to be able to not have to cut that off and re-work it.
How many do you have to do?
