1JZ trigger ecu master
EFI Tuning Fundamentals
Found lost cam sync issue when logging at idle on ecu master black. Was set to failing Hall sensor on primary. Found I could eliminate the cam sync loss with pull down 4k7. Would I be correct for doing this?
All JZ engines have VR sensors for crank and cam.
Unless you have aftermarket sensors you should have the sensor type set to VR not hall.
Sorry my mistake double checked it is on VR sensor but still wondering if the pull down was the right move to cancel lost sync
