Alpha N on Weber DCOE
EFI Tuning Fundamentals
Hello,
Try to set an Alpha N on an '68, 4 inline engine, Weber Dcoe and TPS for load.
Can somebody explain what sync start mult. and sync loss mult. mean, how to set up and check if values are right?
What ECU / Software are you working with?
Nodiz GenX / Meite software.
This isn't an ECU I've ever come across sorry. Have you got a manual for the ECU and does that not provide any guidance on these parameters?
Motorsport Electronics, Based in the UK.
Their products have very close connections to Megasquirt ECUs & Tuner Studio software
I imagine the Sync start will be the position of the engine in relation to the Trigger
Sync Loss is where the Ecu loses synchronisation with the engines position
