Hi all,
I'm completely new to tuning and planning to start the HP Academy courses. Before I sign up, I'd really value some advice from experienced tuners on my first project.
The bike:
- 2012 MV Agusta F4R (inline 4, 8 injectors – primary and secondary)
- Stock Magneti Marelli 7BM ECU, still on the factory map, never flashed
- Cat removed and replaced with a straight decat pipe into a lighter aftermarket 4-outlet silencer (stock silencer removed)
- Currently running lean and doesn't feel right, which I put down to the exhaust changes with no fuelling correction
What I'm after is basically a Stage 2 map to suit the freer-flowing exhaust. As far as I can tell, these are my options:
1. Reflash the stock 7BM ECU (e.g. with ECU Studio or similar), using the factory calibration as my baseline and adjusting fuel and ignition from there
2. Use a piggyback module (Rapid Bike, JetPrime, etc.) – but I've read some only drive 4 of the 8 injectors and don't touch ignition or the O2 sensor
3. Go to a standalone ECU and build a map from scratch, using the stock calibration values as a reference
My questions:
- Which route would you recommend for this bike, and why?
- Is the 7BM fairly well supported for reflashing, or is it a difficult platform to work with?
- Is a standalone realistic on this bike, considering the 8 injectors, ride-by-wire/throttle setup and dash integration, or is that overkill for a Stage 2?
- What should I deal with on the O2 sensor and closed-loop side, given the cat is gone?
- After completing the relevant HP Academy courses (EFI Tuning Fundamentals, Practical Reflash Tuning, etc.), would a beginner realistically have enough knowledge to attempt this, with guidance from the forum?
I don't have much MV dealer or tuner support where I live, so I'd really like to learn to do this properly myself instead of relying on someone else. I'm also keen to get onto a dyno to do it right.
Any advice, warnings or experience with MV F4s would be greatly appreciated.
