Cummins MAP/IAT sensor combo, p/n 2897333
EFI Tuning Fundamentals
Hello all, I'm in a space constraint issue and found a 90 deg MAP/IAT sensor from Cummins. (4 pin)
I wanted to see if anyone has used or mapped out the IAT or MAP sensors yet. (trying to use a MS3pro)
I'd really like to avoid the GM IAT because I'd lose a bunch of space without refabricating my aribox. (it'd stick out the back)
Worst case, I can try find an angled bung for the GM IAT. (i want to mount on the back face of the airbox)
Thanks
Looks just like the Bosch T-Map sensor. You might test to see if the calibration matches, you can see the datasheet on this page:
https://www.bmotorsports.com/shop/product_info.php/cPath/129_143/products_id/2270
oh awesome!!
had i known this was available i would have gotten this one from the start.
cummins wouldn't provide me any data specs on the thing when i asked, so annoying.
even has the associated connectors on that website!!
Just to be sure, for a naturally aspirated application, the 1 Bar version sufficient, right?
1 Bar = 14.5 psi (around atmoshpere), so everything should be vacuum from there right?
Yes, that is correct. It is a 1 bar absolute pressure sensor. it's range is from 10 kPa to 115 kPa (1.4 to 16.67 psi Absolute)
