Ecumaster black- sensor help
EFI Tuning Fundamentals
So I discovered real fast that hptuners and my ecu were very limited in terms of available data stream and configurable fields. I was at a cross roads and opted to go stand alone for my build. I have a 2.5 out of a 2015 ford fusion that I've added a turbo, upgraded injectors, and swapping to speed density. This sits in a 74 mg midget. I went the rought of black emu. Now im getting into the a actual configurable sensor data. First thing I noticed is that my cam sensor is an mre, emu offer hall or vr. Not sure where to find data for my coils, dwell. Injectors are fic so I should have data. Coolant sensor values im unsure of. Crank sensor I believe to be a vr, think I just need to set crank pattern. Knock sensor values Im not sure. Intake air I found when I purchased. Vvt I'm not sure on. Any help is greatly appreciated!
