fans for cooling
EFI Tuning Fundamentals
Hello everyone! I looked through the lessons but didn't find an answer (if so, I apologize). I'm building drift cars, what do you recommend for the radiator fans? One large Spal fan? Two Spal fans distributed across the radiator? Do you recommend an air duct where I can mount my intake fans? Thank you, how can I mount them? Thank you.
Fans are definitely more effective with shrouds & ducts. Certainly worth doing.
I like using Pull fans. The number depends on the radiator shape. Nothing wrong with a big shrouded puller fan if you can fit it. I would mount the fans to the shroud.
the mesurement of radiator it's 66cm x 45 cm
i think i'll use 2 fans
