Intake Air Temp Sens
EFI Tuning Fundamentals
Relevant Module: EFI Components > Intake Air Temperature Sensor
I'm wondering where I should place my intake temp sensor on my drag car. I'm running a nitrous outlet wet plate system. I worry about putting it in my manifold do to heat soak but It wont be reading the -130 degree nitrous oxide if its in the intake pipe because that gets injected right before it enters the manifold.. I currently have the sensor in my intake pipe. is this a good spot for it. fairly soon I will be converting to a MAP so does none of this matter? Thanks
Depending on the ECU, I would expect you could compensate for the additional cooling gain from the nitrous flow. i would leave it upstream of the throttle, particularly for a drag car.
