New to HPA . New to Tuning . RB tune and Qestions EFI course completed
EFI Tuning Fundamentals
Hi All
Great to be here!
I have an RB26 that was previously tuned by a reputable tuner. Since then, I've fitted a Nismo intake collector plenum, and I've noticed what feels like flat spots in the power band.
The car is running a new Haltech Nexus plug-and-play ECU.
I've pulled the datalog and noticed a difference between the target lambda and actual lambda, which I'd like to correct.
Based on the log, I believe I need to increase the fuel table values by approximately 6–9% between 5,500 and 7,500 RPM, as this appears to correspond with the lambda deviation I'm seeing.
I'd appreciate your thoughts on whether this is the correct approach, particularly given the change to the Nismo intake collector.
Hi Steven,
It certainly looks like it's gained a lot more flow if it was originally running on target; the injectors are levelled out and lambda is climbing, I would also consider that maybe the fuel pump is struggling, or maybe a low fuel level issue as this looks like a 1st, 2nd 3rd gear pull going by the oil pressure.
Was the fueling strategy Alpha-N with boost compensation when it was the stock ITBs? If so, it tends to be more than just gross fuel needing to be addressed in a single block of cells.
