No spark or RPM signal on Crank K11 Micra + Haltech Elite 1500
EFI Tuning Fundamentals
Hey everyone,
setting up my haltech 1500 for my k11 micra and having an issue where im getting no spark or rpm reading when cranking. I have triple checked the wiring and I have the Cam position sensor signal to the Crack Trigger + pin on the ecu and the ignition to the IGN 1 pin on the ecu. I have also checked and the ignition coil and cps is getting 12v and all grounds are connected. Anyone have some advice for things to try
