12v Bench test unit?
EFI Wiring Fundamentals
What are people using for bench testing looms and ecu setups?
iv been looking at a 10-30v power unit on amazon for powering up ecu’s on the bench for testing of loom & hardware before install.
I like those power supplies that have adjustable voltage and current limiting with digital displays. You can set it to a low limit when first powering a new loom to make sure some fatal short won't take out the wiring.
I can't find the one I bought 15 years ago, but it's similar to this:
https://www.amazon.com/LW-K3010D-Adjustable-Switching-Regulated-Spectrophotometer/dp/B07512KQDW/
Thanks for your reply
that’s very similar to the one iv been looking at.
would also be handy for testing amp draw on accessories
A small suggestion I will add - Avoid the ones that only have the +ve/-ve connection posts, these will usually have the -ve post tied to mains ground. Look for one that also has the separate ground post as the negative is usually isolated in that case.
With a non isolated negative you can easily damage things with scenarios like a USB powered oscilloscope or logic analyser connected to an ECU output.
