94 R32 GTR build
EFI Wiring Fundamentals
so here’s my 94 R32 GTR build. Unfortunately the 2.8 spun a bearing and now in the process of building a nitto 3.2 bottom end.
Engine:
HKS 2.8 stroker step 1 86.5mm
ACL Bearings
ARP Main studs
ATI 1000hp balancer
Platinum Racing rb26 brace
Garage101 extended sump
N1 water pump
Nitto oil pump
ARD 140amp alternator
Head:
Kelford Cams 274 10.55m (182-S)
Kelford Cams CNC’d ported head
Ferrea +1mm oversized valves
Kelford Cams beehive springs
Kelford Cams titanium retainers
HKS Cam gears
Nitto 1.2mm headgasket
ARP ca625+ headstuds
Nitto gaskets inlet/exhaust
Spool head drain
Hi octane direct cam baffles
Turbo/manifold:
6boost promod vband manifold
Turbosmart progate 50mm wastegate
4” dump pipe to 3.5” system
AES resonator and muffler
Garrett G42-1200 1.01 rear
Fuel system:
BPP Fuel rail
Bosch 1650cc injectors
Turbosmart fpr 1200
Frenchys performance garage twin intank
Walbro 525 fuel pumps x2
-8 feed speedflow 200 series hose
-6 return speedflow 200 series hose
Ignition:
Platinum Racing r35 coil kit
Platinum Racing trigger kit
NGK Copper spark plugs BCPRE7ES gapped .6mm
Wheels, Brakes & Suspension:
Work Meisters 18x10.5 +12 offset
DBA T3 4000 series discs front and rear
Intima SR brake pads all round
Nitto Invo 265/35/18
HKS Hipermax iii coilovers
Transmission:
Getrag 6speed
Direct clutch services 9” twin plate
Engine management:
Link G4X plug in
Link can lambda kit
Bosch oil temp & pressure sensor
Bosch fuel pressure sensor
Flex fuel
Tuned by Mick
1011hp (753kw) @ 37psi e85
923hp (688kw) @ 35psi e85 (high boost)
753hp (561kw) @ 24psi e85 (low boost)
685hp (510kw) @ 20psi on BP98
Sounds like a fun setup. Sorry you've had to rebuild!
